Hi there,
I would like to have a blank base map for cases where I am offline, but users still want to see the points they have captured relative to one another.
To do this, I use the following (which works on 100.7 and below), but it crashes. What am I doing wrong?
Thanks!
import QtQuick 2.6
import QtQuick.Controls 2.2
import Esri.ArcGISRuntime 100.9 as Esri
ApplicationWindow {
width: 800
height: 600
title: "ImageTiledLayer bug"
Esri.MapView {
anchors.fill: parent
focus: true
Esri.Map {
Esri.ImageTiledLayer {
fullExtent: Esri.Envelope { xMin: -20037508.34; yMin: -20037508.34; xMax: +20037508.34; yMax: +20037508.34; spatialReference: Esri.SpatialReference { wkid: 3857 } }
noDataTileBehavior: Esri.Enums.NoDataTileBehaviorBlank
tileInfo: Esri.TileInfo {
origin: Esri.Point { x: -20037508.34; y: +20037508.34; spatialReference: Esri.SpatialReference { wkid: 3857 } }
dpi: 96; tileWidth: 256; tileHeight: 256; spatialReference: Esri.SpatialReference { wkid: 3857 }
levelsOfDetail: [
Esri.LevelOfDetail {level: 0; resolution: 156543.03390624999884; scale: 591657527.50934994221}
, Esri.LevelOfDetail {level: 1; resolution: 78271.516953124999418; scale: 295828763.7546749711}
, Esri.LevelOfDetail {level: 2; resolution: 39135.758476562499709; scale: 147914381.87733748555}
, Esri.LevelOfDetail {level: 3; resolution: 19567.879238281249854; scale: 73957190.938668742776}
, Esri.LevelOfDetail {level: 4; resolution: 9783.9396191406249272; scale: 36978595.469334371388}
, Esri.LevelOfDetail {level: 5; resolution: 4891.9698095703124636; scale: 18489297.734667185694}
, Esri.LevelOfDetail {level: 6; resolution: 2445.9849047851562318; scale: 9244648.867333592847}
, Esri.LevelOfDetail {level: 7; resolution: 1222.9924523925781159; scale: 4622324.4336667964235}
, Esri.LevelOfDetail {level: 8; resolution: 611.49622619628905795; scale: 2311162.2168333982117}
, Esri.LevelOfDetail {level: 9; resolution: 305.74811309814452898; scale: 1155581.1084166991059}
, Esri.LevelOfDetail {level: 10; resolution: 152.87405654907226449; scale: 577790.55420834955294}
, Esri.LevelOfDetail {level: 11; resolution: 76.437028274536132244; scale: 288895.27710417477647}
, Esri.LevelOfDetail {level: 12; resolution: 38.218514137268066122; scale: 144447.63855208738823}
, Esri.LevelOfDetail {level: 13; resolution: 19.109257068634033061; scale: 72223.819276043694117}
, Esri.LevelOfDetail {level: 14; resolution: 9.5546285343170165305; scale: 36111.909638021847059}
, Esri.LevelOfDetail {level: 15; resolution: 4.7773142671585082653; scale: 18055.954819010923529}
, Esri.LevelOfDetail {level: 16; resolution: 2.3886571335792541326; scale: 9027.9774095054617646}
, Esri.LevelOfDetail {level: 17; resolution: 1.1943285667896270663; scale: 4513.9887047527308823}
, Esri.LevelOfDetail {level: 18; resolution: 0.59716428339481353316; scale: 2256.9943523763654412}
, Esri.LevelOfDetail {level: 19; resolution: 0.29858214169740676658; scale: 1128.4971761881827206}
, Esri.LevelOfDetail {level: 20; resolution: 0.14929107084870338329; scale: 564.24858809409136029}
, Esri.LevelOfDetail {level: 21; resolution: 0.074645535424351691645; scale: 282.12429404704568014}
, Esri.LevelOfDetail {level: 22; resolution: 0.037322767712175845822; scale: 141.06214702352284007}
, Esri.LevelOfDetail {level: 23; resolution: 0.018661383856087922911; scale: 70.531073511761420036}
, Esri.LevelOfDetail {level: 24; resolution: 0.0093306919280439614556; scale: 35.265536755880710018}
tileCallback: function(level, row, column) {
return ""
