In the snippet below you can see that I am calling ms.pageRow.PageName to get the value for the field named "PageName" in my Index Layer. This is how all the sample code I have found does it. But, how can you do this using a string variable for the field name? For instance you want to pass in the field name as an argument to the script. I have tried getValue("PageName") like you see in the SDK documentation, but that does not work. Any ideas?
if not lyt.mapSeries is None:
ms = lyt.mapSeries
if ms.enabled:
for pageNum in range(1, ms.pageCount + 1):
ms.currentPageNumber = pageNum
page = ms.pageRow.PageName # <-- ??How to use a variable field name here??
print(" - {0}".format(output_path + f"file_{page}.pdf"))
lyt.exportToPDF(output_path + f"file{page}.pdf", resolution = 300)
