Hello,
Is anyone else having issues when running Enable Network Topology (Errors Only) after the 2.4.2 release? I have gone through the process of staging a new network, applying the asset package and loading the data at least 5 times in the past 4 days. Everything completes successfully until I run Enable Network topology. Without fail, it fails. The error message doesn’t provide any useful information or hints at a possible cause. I’ve attached a screenshot of the error message I’m seeing. Any thoughts or suggestions on possible causes would be greatly appreciated.
thanks!
Hi Tyler,
Few questions:
If you share the asset package, I can take a look. pleblanc@esri.com
I tried and it works fine.
I would like to ask you to check the UNtools version that should be v2.4.2. if not update the package.
I faced this type of problem previously and as a workaround, I tried following steps that went well for me.
Hope this will help you.
Good Luck!
Manoj
You probably have checked, but
1. Is your EGDB connection set as branched version?
2. Is UN dataset registered as versioned?
3. Do all datasets have globalids?
