<\/HEAD>
Mám výraz atributu používaný v popup okně, které se zobrazuje v ArcGIS webové mapě, ale ne ve webové aplikaci nebo v collector.<\/P>
<SPAN class="keyword token">var<\/SPAN> relatedData <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">FeatureSetByName<\/SPAN><SPAN class="punctuation token">(<\/SPAN>$datastore<SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"RelatedData"<\/SPAN><SPAN class="punctuation token">)<\/SPAN>
<SPAN class="keyword token">var<\/SPAN> filteredRelatedData <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">Filter<\/SPAN><SPAN class="punctuation token">(<\/SPAN>relatedData<SPAN class="punctuation token">,<\/SPAN> <SPAN class="token function">Concatenate<\/SPAN><SPAN class="punctuation token">(<\/SPAN><SPAN class="string token">"id="<\/SPAN><SPAN class="punctuation token">,<\/SPAN> $feature<SPAN class="punctuation token">.<\/SPAN>id<SPAN class="punctuation token">)<\/SPAN><SPAN class="punctuation token">)<\/SPAN>
<SPAN class="keyword token">var<\/SPAN> orderedFilteredRelatedData <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">OrderBy<\/SPAN><SPAN class="punctuation token">(<\/SPAN>filteredRelatedData<SPAN class="punctuation token">,<\/SPAN> <SPAN class="string token">'date DESC'<\/SPAN><SPAN class="punctuation token">)<\/SPAN>
<SPAN class="keyword token">var<\/SPAN> newest <SPAN class="operator token">=<\/SPAN> <SPAN class="token function">First<\/SPAN><SPAN class="punctuation token">(<\/Span>orderedFilteredRelatedData<Span class="punctuation token">)<\/Span>
<Span class="keyword token">if<Span class="punctuation token">(<Span class="token function">IsEmpty<Span class="punctuation token">(<Span>newest<Span class="punctuation token">)<Span class="punctuation token">)<Span class="punctuation token">{<Span>
<Span class="string token">"n\u00e1"<Span>
<Span class="punctuation token">}<Span>
<Span class="keyword token">else<Span> <Span class="punctuation token">{<Span>
<Span class="keyword token">var<Span> installDate <Span class="operator token">=<Span> newest<Span class="punctuation token">.<Span>date
newest<Span class="punctuation token">.<Span>name <Span class="operator token">+<Span> <Span class="string token">" ("<Span> <Span class="operator token">+<Span> <Span class="token function">Text<Span>(installDate, "Y-MM-DD HH:mm:ss") <Span class="operator token ">+ " )"</span>
<span>}</span><span><<EMOJI_0>><spanclass="line-numbers-rows"><span><<EMOJI_1>></span><span><<EMOJI_2>></span><span><<EMOJI_3>></span><span><<EMOJI_4>></span><span><<EMOJI_5>></span><span><<EMOJI_6>></span><span><<EMOJI_7>></span><span><<EMOJI_8>></span><span><<EMOJI_9>></span><span><<EMOJI_10>></span><span><<EMOJI_11>></span><span><<EMOJI_12>></span></span>
Už jsem se smířil s tím, že to nefunguje v ArcGIS Collector. A teď se zdá, že to také nefunguje ve webové aplikaci. To je opravdu frustrující.<\/P>
Ale hledám webovou stránku nebo dokument, který uvádí omezení Arcade napříč všemi ESRI produkty. Máte nějaký tip, kde něco takového najdu? <\/STRONG><\/P>
PS. Vím, že výše uvedený Arcade výraz není výkonný.<\/SPAn><\/P><\/BODY><\/HTML>
