Would be nice if tables could be stored into FeatureDatatset. Now, the only place to write them is the geodatabase root level... Some tables belong to a FeatureDataset logical theme and so have to be into it.
I am going to make it simple because esri does not seem to listen to customers that have wanted this since the concept of Datasets was introduced.s. t. o. r. e.r. e. l. a. t. e. d.t. a. b. l. e. s.i. n.d. a. t. a. s. e. t. s.!!!Thanks.-Tim
Often it would be helpful to be able to add non-geometry table to Feature Dataset.
Not only because of "using Feature Dataset as a folder" but setting of permissions too and so on.
Some of "why" ideas here:
https://community.esri.com/t5/data-management-questions/tables-in-feature-datasets/td-p/404570
Why is to such a fundamental thing to add? Either add folders oder let people add tables to feature datasets. When you have 3 tables and one featureclass all having relationship classes between each other you can really fast just give up using the Katalog view to find anything...
Feature datasets are specific to storing spatial data that participates in a controller dataset. Non-spatial tables are not part controller datasets and therefore will not be part of feature datasets.
For more information on feature datasets and their intended use please see https://pro.arcgis.com/en/pro-app/latest/help/data/feature-datasets/feature-datasets-in-arcgis-pro.htm.
@ShannonShields I'm wondering if there are any plans to let users compartmentalize geodatabase contents in the future? When you have a few hundred items in there, it's tough (especially for my lower-level users) to find the exact thing you want.
thinking workarounds?
for any "table" you want to include in a feature dataset,
that will give you access to the "attribute table"
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
