Ouch. I thought you could access simple feature classes from Server, but it seemsas if it can't. Working around that will wander into unsupported realms. How urgentis your SQL insert requirement?- V
vangelo,When I tried to publish an mxd in arcmap 10.2, a dialog box came up saying the table was not registered and the data had to be copied to the server. The words copied to the server make it sound like a one time upload of the data, meaning any inserts after the publication would not be viewable. Maybe I am just misreading the dialog box. Would you explain how you would publish a map service of an unregistered table, so that the sql inserts will be seen after the initial publication?Thank you.
