This is Fji and since the dateline passes through here we have this issue. Is there a way to " wrap the world around the dateline" like you can do in ArcGIS Pro?
Hi Anare,
While you can't do anything about this in the Mapboards window of Maps for Creative Cloud, you can work around it in the Compilation window. In the screenshot below, I set the basemap to 'VectorStreetMap', and set the projection to 'Fiji 1956 UTM Zone 1S'. The standard raster basemaps cannot be reprojected, but a vector option like 'VectorStreetMap' or 'Natural Earth' can be, and should accommodate this workflow.
Steve
Thanks Steve. Eventhough I would rather use a more updated projection the idea you have should suffice. Thanks again.
