Hi!
I have a problem with Attachement Viewer. The app doesn't load attributes of my objects. It says literally "no available resources". The app works on a web map that is used in many other apps and everything works fine there.
Hi Maciej,
Would you be able to provide the link to the app? Are you using any custom attribute displays like arcade or pop-up media?
Thanks!
Sarah
Hi, this app is not public. But the layer (public transport stops) is available in some public apps. I find problems with this specific layer in dashboard (beta) - no attributes, in map viewer (beta) - the layer is invisible, in experience builder - no attributes. You can open this map in dashboard/map viewer/ experience builder --> https://um-warszawa.maps.arcgis.com/home/item.html?id=eafe003e18044408adbcd860006ca7f0
As I said before, the layer works well in "old" apps.
