I have used an ESRI template which was downloaded from GitHub and I want (a) to change the dimensions or position of the frame which includes the title and (d) to add more widgets.
To answer part of your second question change
floatingtheme/widgets/FloatingHeader/css/style.css
Change the % to any you want. Also the max-width calc the theme is set up to -60px from 100% but if you want it to cover the whole page delete the line.
Change line 18& 19
jimu-widget-floatingheader { width: 100% !important; max-width: calc(100% - 60px);
Barbara,
What template did you download from Github?
Hello Rickey,
I downloaded this one..
EsriCanada/WAB-FloatingTheme · GitHub
Do you have the developer edition downloaded or did you create your app on AGO?
I have the developer edition.
Have you moved the downloaded theme into the theme folder in the web app builder files?
Have you set up the developer edition on a server?
Yes and yes and I have already made my first app. And now I want to make changes... to many things concerning the data and symbology and also to the theme and add some more widgets.
ArcGIS Web Application http://webgis-mfk.geol.uoa.gr/Life_Oiti/
