Hello,
Please see screenshot. I have an AppStudio 4.0 Desktop Edition with Survey123. Edit in QT creator. Is there a way to display surveys without download surveys? *no sign in/no portal. Just for the public use. Please advise. Thank you!
cc: Survey123 for ArcGIS cc: AppStudio for ArcGIS
Similar to this, https://community.esri.com/thread/208399-survey123-field-app-to-load-a-predetermined-survey-on-startup
Erwin,
So should I work with OpenParameters page? Could you please suggest what changes should I make to make it finally work?
Thank you!
Yulia,
To my knowledge, using this approach (hijacking the itemid on the open paramater) can only open one Survey at a time, because this is the same as if we are opening the Survey123 field app using custom URL Scheme. https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-scheme
We need to think about a different approach if we want to pre-load more than one survey.
Erwin
Hi Erwin,
I tried for loop to iterate through an array with item ids that I want to download, but it still only downloads the first one when I run. Please look at my code:
THANK YOU!!!
Hi Alex,
I tried parsing several item ids, but it only downloads by one each time you open the app. Did you get it work?
Erwin Soekianto,
I read the link you posted but it is display and open only one survey. Is it possible to display more than one survey? Please let me know.
Thank you.
Alex
