I recently installed portal and have installed and authorized Insights. I am able to access the application but on the my workbooks page I have no workbooks listed and when I hit the Start new workbook button nothing happens. any help?
The documentation is ambiguous as to where the installation needs to occur, in my opinion. Installing Insights on either the Portal machine OR the Hosting server is not enough. The truth is, Insights needs to be installed in BOTH places: (1) Portal for ArcGIS, and (2) ArcGIS Server (Hosting server). This is assuming your have Portal and ArcGIS Server (Hosting server) on separate machines. As mentioned above, if you are running multiple servers for Portal and/or multiple machines for ArcGIS Server, then the installation needs to occur in all of those places.
Just wanted to add a NOTE here on this post:
If you are running ArcGIS Enterprise in a distributed environment, Insights must be installed on every machine running Portal, and the hosting GIS Server. As noted here: http://server.arcgis.com/en/insights/latest/administer/windows/install-insights-windows.htm
"The setup program detects whether Portal for ArcGIS or ArcGIS Server is installed on your machine, and installs the appropriate Insights feature. On a single-machine deployment, you only need to run the setup once. If your Portal for ArcGISis configured in high availability, you need to run the setup program in both portal machines. If your hosting server is a multi-machine site, you need to run the setup program on all of the machines in the hosting server site"
Hope this helps.
Thanks - it turns out it was a couple things.
First, I had issues not being able to create/add content so I changed the unfederated, and then federated again using the admin path for both URLs. That appeared to fix the first issue. Second, I had troubles with creating the workbook and was receiving two different errors; certificate error, and servlet error.
I had a chat with Esri yesterday and we got most of everything squared away, however now I am seeing old items in my insights Add Data page. Here is what we did:
Hey Chris,
Is Insights installed on both Portal & Server, if they are on separate machines? If it is, can you find out if you can publish a feature layer from Create Feature Layer option in My Content in Portal?
When you create a new workbook in Insights, it creates a hosted workspace service in the ArcGIS Data Store of the hosting server that you just refederated. So, if you're having workbook issues, I'd recommend making sure you can do this task first to ensure the Enterprise is up and functional.
Aravind
I too am having this issue.
I removed the federated server, and federated again following the suggestion to use the administrative path for both URLs.
That resolved the issue I saw on this post about not seeing Feature Layer as options in the Add Items drop down menu.
My error changed in Insights to "Error: Create Service error: Servlet execution threw an exception".
Any ideas?
Thanks for more detailed info. I will pass this info along to the ArcGIS Enterprise team.
Regards
I can tell you what was the problem here
If you federate portal and server using the private url (aka the one with phisical machine fully qualified name and ports 6442, 7442) as suggested on the install guide, the data store will NOT work when accessing the portal from the web adaptor url from a machine that cannot access the private url, the same will happen if you publish the portal/server through a proxy.
The only way to make this work for us, was to federate portal and server using the proxy url and port
This seem to be ArcGIS Enterprise configuration issues. Did you get this resolved? If not, I suggest you open a ticket with Esri customer support to get you up and running right away.
Regards,
Doug
I have the same problem, the cause is a certificate violation that fires when you click on the button, for some reason it's trying to call the phisical machine instead of the public domain
Insights for ArcGIS requires a Base Enterprise 10.5 deployment:
If you have this and still see the problem, please go to My Content and choose "Create". You should see the following option in the dropdown "Feature Layer". If you're missing this, then there's probably some issue with creating hosted feature services in Portal/Server.
