Having a little trouble with the output extent feature. I have a county map with density mapped on it. The density colors spill over the county line and I'd like to stop them from doing that. I assumed it was under the extent tab that I would be able to fix this but every drop down I've tried under that tab hasn't worked. Further, when I use some of the drop downs such as "Set the Extent to: The full retangular extent of all layers" then I can't see the density colors at all. When I change that drop down back to "the current setting of the layer" the colors don't come back.
Any advice?
