I want to search by the fields I specified in the web map in the mobile Explorer app. How is this done? Seems worthless if you can't search your objects in the mobile environment.
It should work, which OS are you using Explore on?
Did you set up feature search by layer in the webmap settings?
Why does it only let you specify one search field per layer?
I think that is just a UI design choice that was chosen... You can add the same layer multiple times choosing different fields and Explorer will return results from all of the fields.
You need to set up the search in your web map or wep app
I followed the guidance provided above to configure my web map to search by layer and it works great in my web map. However, the only part of it that works in Explorer is that the 'hint text' appears, while the actual search of the layer does not work at all. Any suggestions? I would be happy to email someone some screenshots, etc. Thanks!
Hey Ashley Hayes,
Which platform and version of Explorer are you using? What do you see for results after you execute the search? Feel free to email me a jwhitney@esri.com and we can discuss further.
Hello,
I'm having similar issues with the Explorer App. I've configured the Search to look up some of our asset numbers. It works in our ArcGIS Online Map when we are using a desktop computer, but it is not working in the Explorer App. When I type in an asset number it just brings up postcodes in Singapore. I'm running App version 20.2.1 and Android version 10. I've attached two images, the first is the Web map application settings showing the search by asset ID. The second is a screenshot from the Explorer App, showing an exact asset number that instead returns addresses in Singapore.
I am also experiencing this. The search is configured in the web map and works in AGOL. I have updated the hint text and this displays in Explorer, but I am unable to search by configured search layers in Explorer. Did anyone ever get to the bottom of this? Also, is it possible to restrict the ESRI Search to one country? I also do not need postcodes from Singapore returned...
Helen
This functionality is currently broken and/or buggy on mobile and web ever since upgrading Pro to 2.7
We have the same problem. Everything was working fine up to explorer version 20.1.0 build 2714. But after the update in october last year to version 20.2.2 build 2747, search stopped working! Hope it will be fixed soon...
