I am joining 2 layers (i.e. attribute tables). I am trying to get all values to show up in both layers in the join. In stead, I get the features that are related and then it nulls out the rest. Am I missing a step in Pro??
Hi Michelle,
Could you please provide a code snippet showing what you are trying to accomplish?
--Rich
So, I would be joining 2 layers with the field BridgeID in both tables. The end result I would like them to be joined by Bridge ID and also have all information in the fields showing. Right now, when I join by Bridge ID the joining layer has null’s if there is not a match. I don’t want any nulls. Please let me know if that helps.
Michelle Couden
Cartographer
Certified GIS Analyst
TPP Wellness Contact
Transportation Planning and Programming
Traffic Analysis Section
(512)486-5136
Watch for Cyclists!
Michelle,
Are you trying to do this with the ArcGIS Pro user interface or with C# code? If you're doing it with C# code, what classes are you trying to use?
ArcGIS Pro. I was hoping they made the joining tables/layers improved.
Michelle--
Ah, ok. This is the software development kit forum. I think if I tag ArcGIS Pro they will see it, but you might also try posting it at the Ask ArcGIS Pro section of GeoNet.
