I can't get get it to work, either. I have enabled attachments and have tested in in ArcGIS Desktop 10.1, SP1 But when I attempt to load an attachment in ArcGIS Online, I receive an error: File Type not supported. I am just trying to attach a .jpg. The ultimate goal is to serve this up on an Android device, using the ArcGIS App from Google Play. Any help is appreciated at this point...Kat
Unfortunately, you can't display image attachments inside the popup window. What you can do, as you found in the doc, is you can check the box when configuring the popup window to display links that represent your attachments (see attached image). When you click on this link in the popup window, the browser will download the attachment to your computer.We do want to support the ability to view attachments in the popup window. We just haven't done so yet.Thanks,Mike
I'm using ArcGIS Online, and I'm trying to show attachments, but I don't see a checkbox to enable attachments in the configure pop-ups window. Am I missing something?
MS
If a given feature has attachments, then they will show up automatically as links in the popup window. Clicking on a link will allow you to view the attachment. Unfortunate, for example, if you have an image attachment, it won't draw in the popup, or show as a thumbnail. This is a performance limitation, as the file can be large and would require a full download. So if you had say 2 images of 5mb each, that's a 10mb download to display them.
Are you attempting to display attachments on an ArcGIS Server feature layer or a hosted feature layer in ArcGIS Online? If you published your data to ArcGIS Online and created a feature layer, you need to go to the item details page of the feature layer, look for the list of sublayers and click the small arrow next to the name to enable the layer to support attachments. Once you've done that, you can add attachments, and thus view them.
Mike
I think I'm trying to display attachments on a hosted feature layer in ArcGIS Online.
I posted this to another thread, but I'll repeat it here:
I have a single license of ArcGIS Basic, which comes with a subscription to ArcGIS Online. Do I have access to show attachments on ArcGIS Online? What's an organizational subscription?
I made a new map in ArcGIS Online, and added content as zipped shapefiles to the map. When I click on Configure Pop-up, I don't see a checkbox to "show feature attachments as links", as described in the help information.
Thanks!
If you added the shapefile to the web map directly, then there is no ability for attachments on popups, because the data is being stored directly in the map.
If you add the shapefile to your My Content, then you have the option to publish it as a feature layer. Feature layers do support attachments, and you enable them from the item details page like I described above. When you publish a layer in this manner, the features are stored in a database that allows you to add attachments.
Hi Mike,
Quick question is there a time frame when photo attachments will be available in the pop up? as a photo not a link to the photo
Matt
No definite plans yet. We are discussing it. One of the main issues is performance. It's not uncommon for an image to be large in size. If you have a number of images as attachments, it can be a lot of data to send across. Currently, we would have to send the full image, as we don't have a way to create and store a small thumbnail version of it.
Hi Mike.
From a usability perspective, it would be ideal if AGOL could take the service with attachments and generate thumbnails itself, or if there was a tool in ArcGIS to do that automatically before uploading. I could see how that could easily get intensive very fast though. I'm curious as to how Operations Dashboard solved this problem.
Stephen Shepard - if you upload data to a hosted layer in arcgis online, I believe the attachments come with it. I'm not sure how ArcPad works with arcgis online, however.
Matthew Proctor-Brown - I agree with you. Ideally, you would not have to generate thumbnails yourself and the system would just handle it automatically.
