I have added and shared a CSV onto Portal.
item = gis.content.add(file_properties, file) item_share = item.share(everyone=True, org=True, groups=None, allow_members_to_edit=False)
How do I retrieve the share-url?
Greg
Hi Greg,
You can obtain the item id from your item variable (item.id) and append it to a URL with /data at the end. Here is an example URL:
https://<portal.domain.com>/<webadaptor>/sharing/rest/content/items/<itemid>/data
Jake,
That worked.
Thanks.
I am trying to use this format to generate share links for some of my webmaps. But when I try this URL format it just returns JSON. How do I make it return the webmap as a public link?
