I got houndreds of dwg files and DTM from a Geophysical survey for a submarine cable route (They are from alignment sheet). When I try to import them into ArcGIS (Desktop 10.2) it shows the message about the "Unknown Spatial Reference".
I have an .mxd with the Coordinates and projection already set up for that project.
Does anyone know why if I ignore this message sometimes it is drawing the dwg in the right place and sometimes not?
If I try to convert them in shp in the first place and I try to give them the same coordinate system and projection from the data frame, it doesn't really work for all of them. Some of them are projected in the right place and some not.
