I know there are other options:
Thanks for any pointers.
Hi Simon,
Is this what you are looking?
arcgis.features module — arcgis 1.5.2 documentation
Or you can use edit_features(adds=None, updates=None,....)
There is an example for it
updating_features_in_a_feature_layer | ArcGIS for Developers
Hope these information are useful for you
Cheers
Hey again Simo
No its not so much the actual appending, its the uploading of a fGDB against the Hosted Feature Service itself (as opposed to an item in the portal) which I cant spot an easy way of doing without using the requests library and working directly with the REST endpoint.
Will see if I can share some code. Here is a Javascript equivalent.
Hello Simon,
It seems we have to do it in two steps:
Step 1: update the File Geodatabase item
Step 2: use the File Geodatabase item to update the Feature Service via append function which supports upsert.
I did a quick test here, and it seems works fine.
It would be good if we can update the feature service using zipped FGDB directly. and I don't know why the API doesn't. Hope someone from the development team can comment on this.
But we can workaround it by delete the zipped FGDB item after the update. I am just guessing, it really depends on your own workflow
You can actually bypass the above approach of uploading directly to the portal as an item (still a very valid approach for appending) and upload your fGDB directly against a hosted feature service.
Benefit is that this data is manually cleaned automatically by the back-end Server and no reliance on you having to delete.
Appending definitely supports using this via the appendUploadID parameter on the REST endpoint.
But with the Python API:
I am ok working around this by using the requests module, but might be worth including in a future release?
I see.
There is a method called upload for the FeatureLayerCollection class.
but the append function for FeatureLayer does not have a upload_id parameter, and in the source code I can see the upload_id was intentionally set to None. So I assume the upload_id was deliberately disabled for the function.
