How can I get a trial license for Navigator for ArcGIS? I want to try it before I make a decision to use. I downloaded it but there is no way to sign in with Organizational account until I can enable the Navigator license.
Hello,
The trial process is described on the Marketplace listing, esri.com page, and doc page (links below).
If you do not yet have an ArcGIS Online subcription, Navigator is part of the ArcGIS Trial.
http://www.arcgis.com/features/free-trial.html?origin=navigator
Or, if you already have an ArcGIS Online subscription and want to add a trial to it, you can email services@esri.com and provide your customer number, subscription id, name and contact information. They will add a trial to your existing account.
https://marketplace.arcgis.com/listing.html?id=b2d9a4dd70174fac8986dd2bf15a477a
FAQs—Navigate | ArcGIS
Thanks, hopefully that will clear it up! -scott
Does anybody know if Navigator is available under ESRI's not for profit program?
Hi Jason,
Navigator is not included with the not-for-profit program, but you could of course add it to that separately.
Scott,
Thanks for the info.
If an organization was looking at implementing Navigator would they first need a AGOL account with a named user?
Yes, that's right- to use Navigator you need to be a named user of ArcGIS Online or ArcGIS Enterprise, and also have a Navigator license.
Thanks Scott,
Is there a requirement that the ArcGIS Online named user needs to be a Level 2 Contributor to have data pushed down to Navigator or can that user just be a level 1 viewer?
Navigator comes with access to a library of Navigation maps (see below link). If your organizaiton wants to customize those maps or create your own Navigation maps in ArcGIS Pro, that user needs Level 2 capabilities.
http://www.arcgis.com/home/group.html?id=5f430cab7f2b4cb5926bb9fe4e054ecc#overview
Our organization does have Level 2 and ArcGIS Pro 2.0. We were approached by an outside a non profit that would like to leverage and access our authoritative NG dataset. They are considering applying for NGO so they would have their own AGOL account. I was not sure if a level 1 user in a separate AGOL account could pass our authoritative data down to Navigator.
To share content with an organization, it requires a L2 account.
Levels, roles, and privileges—ArcGIS Online Help | ArcGIS
So a L2 user would need to share the map to thie ArcGIS Online Org, and then a L2 user with Navigator could access it, download it, and then use it.
Scott, with Navigator, is there any way to implement offline USNG or MGRS location search and routing. I have both the 1000m and 100m grids that can be placed in the mobile map package. I could then build a locator to find those features. The question is wow can we provide a search, locate and route for smaller 1m USGN/MGRS features that we can't load into a mobile map package? I see it possible to search and locate 1m USNG locations using the myUSNG app while offline. I'm just not sure how they implemented it.
USNG and MGRS location search is not supported in Navigator today. I see that the myUSNG app provides this behavior, but I'm pretty certain that this was implemented with custom code, rather than geocoding functionality with a locator and a style. We are working toward supporting this type of location search in new locator technology in 2018, and that will work it's way into Runtime, and then Navigator (and other apps).
Thanks Scott...
I'm glad its in the pipeline that will be a great feature.
What about custom raster tile package basemaps in Navigator. I thought I saw that this also might be coming...
For the moment Is there a way to side load a tile package directly to the device that Navigator can use.
I see that there might be something for Survey123 and Collector can do for side loading.
Cheers
Jason
Rasters in the .mmpk that Navigator uses - that's something we are also looking at.
Today you can side load the .mmpk onto the Navigator device. Through iTunes for iOS or for Android it's the "ArcGIS/mmpks" folder.
