I need to check for the existence of a raster in the project database. Does anyone have the C# code for ArcGIS Pro?
Hi Sam,
Try code below. FilePath is your raster path in geodatabase. Instead of creating layer you can do what you want
private Task AddToMap() { return QueuedTask.Run(() => { try { // first we create an 'Item' using itemfactory Item currentItem = ItemFactory.Instance.Create(FilePath);
// Finally add the feature service to the map // if we have an item that can be turned into a layer // add it to the map if (LayerFactory.Instance.CanCreateLayerFrom(currentItem)) LayerFactory.Instance.CreateLayer(currentItem, MapView.Active.Map); } catch (Exception ex) { MessageBox.Show(ex.Message, "Error while adding vector tile to map"); } }); }
Perfect!!!! thanks Gintautas.... much appreciated.
