Hello,
we are exploring Explorer for ArcGIS. I am interested in how to sharing the markups that field crew put on the map? Any requirements when prepare the map?
https://community.esri.com/groups/explorer-for-arcgis?sr=search&searchId=ae04c459-275a-44d4-8d4e-22d9079095b4&searchIndex=1
Thanks for your question. When you work with markup in Explorer, it is saved as a layer on your device (it isn't associated with a particular map). As such, there are no restrictions on making maps for use with markup. You can share it across maps on a single device by viewing that layer with different maps open. To share it with other users, you have a few choices:
Thanks Kylie for your quick response. It's great to know all these different choices. So just follow up, how do I share as a markup item in my organization or share it to another device or user?
I was not able to locate any specific documentation and your response will be greatly appreciated.
Yuying
While you are editing the markup, there is a Share button (the box with an arrow). Tap that and you'll see the sharing options.
We are adding documentation on this, so that part will improve
Hi Kylie,
Thanks….when I click the “Share Button” (the box with arrows ) next to the Pen tool, nothing popped up. I made sure I signed in ArcGIS online…anything I am missing?
Yuying Li, GISP
D 858.712.8381
hdrinc.com/follow-us<http://hdrinc.com/follow-us>
I should have been more clear (I was looking at an iPad and forgot about that button you are seeing) -- that button lets you pan the map when using a phone. The box with an arrow that I meant to point out is the bottom right corner on an iPhone, and is a standard icon on iOS.
Thanks! I tried…but didn’t have the iPhone share bottom popped up –
So here are my steps –
1. Add markup
2. Select the markup
3. The options are: delete, make it arrow line or not, change the colors.
See my screenshot – How do I do to show the share button?
Now I see where you are. You don't want to have a particular piece of markup selected as it is shared as a layer. Close the info about "Test" -- the tools on the bottom toolbar will change. You'll see "Clear All, +, Share" where share is an icon.
Nice…sorry…not sure I would miss that…I was able to share to the ArcGIS online as items. Looks like they are feature layers too…but can I download them?
I have a .markup file from one of my field workers that I'd like to view and put on ArcGIS Online. When I try and side-load this .markup file into explorer on an iPad I don't see it when I open any maps. How do I import a .markup file that isn't being directly shared with explorer? Is there any way to convert this file into any other format that I can actually view? I can't add the .markup file directly to ArcGIS online so was hoping that I could open it in explorer and then share it from within the app.
Hey Sam Hopkins, what workflow are you trying to accomplish? As you read in Kylie's response above there are a few ways to share markup. If you want to view the markup in ArcGIS Online, you can share the markup as an item to ArcGIS Online. This will create a read-only Markup layer that can then be added to a Web Map or just viewed in the Map Viewer. Your field worker should also be able to Mail you the Markup, which would allow you to import the markup into Explorer on your device. From there, you could view the markup on your device, or share it to ArcGIS Online.
Hello Joel, my issue is importing the markup into explorer on my device. My field worker was able to mail me the .markup file but I couldn't get the layer to be visible on my device. I tried side-loading it on to an iPad through iTunes but when I opened the associated maps his markup was not visible. What is the correct process for importing a .markup file onto an IOS device?
Hi @VHolubec - I no longer work on the field maps team. To make sure you get the right info, @Anonymous User would be a better person to ask.
Thank you @Kylie. Hello, @Anonymous User, I would like to ask if there is a way how to open the .markup file you get via mail from the user in the filed from Explorer/Filed Maps in PRO?
The PRO seems does not recognize .markup file nor the .makrup file can be uploaded back to AGOL. The only way which works is to share the markup directly to AGOL from the app and then open it in PRO. But the question is what to do with those file which was sent by mail.
Thank you for any idea.
