Hello All,
My question is that: On my ArcGIS Earth App, I can access the data from Living Atlas, but when I use my own data published on my own portal, the App showing, "Unable to Access Data"? Can someone help me with this?
Rauf
Are you logged into your Portal using the Enterprise Login?
Hello Robert,
Yes, I am using the Enterprise Login and I can see my own published maps!
I am talking about the IOS app, not the Windows one, which I have not tried it yet!
Okay, understand. I just downloaded the iOS ArcGIS Earth app to my iPhone, logged into my AGOL account and can see My Content and associated feature layers, web maps and such. The difference here, I believe, is you're logging into your on-prem portal vs. AGOL, correct?
Yes, that's correct! I am using my own portal!
Interesting. Okay try a few things listed here and let me know what you discover:
Great suggestions! I will try them now!
Unfortunately, I was not able to access both apps! The first one (Explorer
For ArcGIS) is showing: "The server is using an untrusted certificate"! The
second app (Pulse Secure) is showing: "The server is not responding."
In chatting with one of our ArcGIS Enterprise instructors, she's seen this before! She said it sounds like a certificate issue either not being on the iPhone or the certificate configuration on your Portal is not correct. She provided the following URL to use to troubleshoot - https://community.esri.com/thread/203945-collector-for-arcgis-the-server-you-are-trying-to-connect-cannot-be-verified
