I am trying to create a web app that supports like 10 tabs. I am thinking about modifying this template and add the functionalities in the web app.
Thanks
In 10.3, I had to download the Story Map series and dump in the portal working directory on the server..
Thanks Michael.
Hey Michael,
How do I dump the "Story Map Series" in the portal working directory on the server? Thanks
You would take the MapSeries Folder and dump to c:\Program Files\ArcGIS\Portal\Apps if installed to default. There may be one existing already, rename the existing to _OLD and add the new.
Next time in portal, Map Series will be available under Create >> APP >> Using a Template >> Story Map Series
In that MapSeries folder should be an app folder, resources folder an index.html and license and readme.txt.
Thank you so much @Michael Robb.
