Hello,
I haven't found out how to set the sticky move tolerance in ArcGIS Pro SDK. We want our users not to move features.
Barbara
Hi Barbara,
Pro uses separate move and select tools to help prevent users from accidentally moving features so there was no need to include the sticky move tolerance in the UI or API.
Hey anon,
Just wondering if this feature is still present to some degree? I notice when organizing layouts and what not that there tends to be a minimum threshold for which I have to drag an item for it to actually move on screen. This is particularly irritating when working with very small tolerances, as I have to zoom in exorbitant amounts. Is there a particular setting in snapping to disable one feature from trying to snap to the guide generated by the position of another feature? And is there a way to disable this minimum movement threshold, or sticky move tolerance as it seems to be named?
Thanks in advance.
I really wish we had Sticky Move Tolerance in Pro. While I appreciate that you can set editing in the the List by Editing pane of Contents, there are layers that need to be editable, and we need to be able to prevent accidental moves. I was very happy with how Sticky Move Tolerance worked in ArcMap.
