Got another one here:Go to the Plan Directory and try to "Delete Plan." Nothing happens here that I can tell.Same experience with Delete and Unjoin!?!?Anyone?
"Load Traverse from file" crashes ArcMap every time! This is an add-in called Parcel Fabric Utilities and can be found with the Tax Parcel Editing Template for 10. Although I found a report of this issue in the blog: http://blogs.esri.com/dev/blogs/localgovernment/archive/2010/07/28/parcel-editor-add_2d00_in-enhances-parcel-management-in-arcgis-10.aspx I have not been able to find a solution. I have logged the incident with tech support.So far I have recreated the normal.mxt, Esri folder in my user profile, and the registry key. I will post update when I have one.
