Thank you Rick. I got it generate like the way I want. However, I receive error when generate schematic diagram. It's saying 'Error during schematic diagram generation. Unable to create schematic feature class. The name of the Field is invalid: valid names may contain letters, numbers or underscores.' Please see the attached files for detail the problem. Would this be solve easily?
Yes Thao, when you create your stops, you need to set a property of the stop with a specific Route name. Then when the solver runs, it knows to treat those stops with individual routes.
Hi Aaron,
Thanks for the update on your post.
Hi Rick, I'm trying with your suggestion that using network dataset. Is it possible to create multiple bus route in one solve? How do I do it?
Thanks in advance.
Thao
