So, you're consuming the new service in Desktop? Try the HTML Popup button (see attached). I've found it takes a couple of tries to get the service to respond with the attachments initally so click again if it doesn't work at first. Also, you can check to ensure your service has attachments by looking at the layer's REST endpoint. It should read "Has Attachments: True."
Yes, the package that it references.Open the Layer Package in ArcMap and create a mapservice out of it.Mark
