Hi, I am having the same problem. After configuring the job in Workflow Administrator and then open Workflow Manager, when I select the job and try to add I get the run time error.
Runtime Error
Program:C:ProgramFiles
(x86)\ArcGUS\WMX\Desktop10.2\Bin\WMX.exe
R6034
An application has made an attempt to load the C runtime library incorrectly. Please contact the application's support team for more information
Hi Leonard,
I understand that you are encountering error “Microsoft Visual C++ runtime Library
Runtime Error!
Program: C\ESRI\WMX\Desktop 10.2\Bin\WMX.exe
Please contact the application's support team for more information” when you are trying to create a new job in workflow manager.
You could follow the following steps to get rid of runtime error before uninstalling workflow manager and making changes to this software. Make sure that you have the most recent backup of your SDE geodatabase before using following steps :
1) Download Process Explorer.
2) Start your application and reproduce runtime error R6034
3) Start Process Explorer. In the "View" menu go to "Lower Pane View" and choose "DLLs".
4) In the top pane, locate your application and click on it. The bottom pane should show a list of DLLS loaded for your application.
5) Locate "msvcr??.dll" in the list. There should be several. Look for the one that is not in the "winsxs" folder, and make a note of it.
6) Now, check the path just before your application runs. If it includes the folder you noted in step 5, you've probably found the problem. You'll have to remove the offending entry from the path before running your program to resolve this problem.
7) The batch file simply clears the path before my program runs, so that the conflicting runtime DLL is not found.
You can also refer a third party link mentioned below which are not promoted by ESRI but may be worth reading it.
http://stackoverflow.com/questions/14552348/runtime-error-r6034-in-embedded-python-application/14680947#14680947
Let me know if this does not helps.
Regards,
Nitesh Jauhari
Hi Nitesh,
It seems that the path below is the one which is present just before I run the application and during the error. My question is how do I actually "remove" this offending entry? I'm not a programmer so I don't want to risk touching anything from my OS especially that the path is located under Windows folder. Please see screenshot for your reference.
Leonard
Thanks for the screenshot.
First, make a copy of the "path" variable somewhere on a drive. Then edit the "path" variable from 'Environment Variables' and remove the path of this dll from its current location and place somewhere in the end. Close the WMX application and relaunch it and try to repro the behavior.
Hope this is going to work. If not, let me know.
Thanks & Regards,
ArcSDE Enterprise Geodatabase Analyst || ESRI
I tried what you've said but the problem still persists. Sorry about my previous post but I believe that the Intel iCLS Client is the one conflicting with the program. I also move its path at the end but I still get the Runtime Error.
Any thoughts?
-Leonard
You can see http://support.esri.com/en/knowledgebase/techarticles/detail/42409 Path in system variable C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\ gives problem because in these folders you have C++ Runtime Library. If you update last 'Intel(R) Management Engine Components' C++ Runtime Library is removed from these folder and you haven't this problem.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
