You can see an example on Google Maps or Bing Maps sites.When you drag the map, the map moves smoothly.When you release the left mouse button the map does not stop straight, but stops by the power of dragging the map you made.I think it could be really nice if it will be at the Javascript API.Thanks,Jeff
The example you sent refers to the buttons that located on the sides of the map that performs a smooth map movement. I am looking for a smooth movement by dragging the map with the mouse.Thanks,Jeff
