16:07:10 (lmgrd) Since this is an unknown status, license server 16:07:10 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.16:07:10 (lmgrd) Starting vendor daemon at port 2700016:07:10 (lmgrd) Using vendor daemon port 27000 specified in license file16:07:10 (lmgrd) REStarted ARCGIS (pid 7228)16:07:10 (ARCGIS) FLEXnet Licensing version v11.10.0.0 build 95001 i86_n316:07:10 (ARCGIS) Server started on ServerName for: ACT 16:07:10 (ARCGIS) EXTERNAL FILTERS are OFF16:07:10 (lmgrd) ARCGIS using TCP-port 016:07:10 (ARCGIS) tcp_s is bad!!! Exiting16:07:10 (ARCGIS) EXITING DUE TO SIGNAL 28 Exit reason 516:07:10 (lmgrd) ARCGIS exited with status 28 (Communications error)
