I am having the same problem and am in need of an immediate fix. Is there a work around for this issue? Are there other basemaps available that can be used? If I create my own image service with high resolution aerials we had flown, will this work?
Also, does anyone know if the extralods widget found in the following forum will work? http://forums.arcgis.com/threads/13636-Flex-Viewer-2.1-Increase-maximum-zoom
I am having the same problem and am in need of an immediate fix. Is there a work around for this issue? I do not need a basemap to be shown, I just need to be able to zoom into the vector data added to the project. Are there other basemaps available that can be used? If I create my own image service with high resolution aerials we had flown, will this work? Also, does anyone know if the extralods widget found in the following forum will work? http://forums.arcgis.com/threads/13636-Flex-Viewer-2.1-Increase-maximum-zoom
