Have a look at the below link:http://www.esri.com/software/arcgis/geodatabase/multi-user-geodatabaseCheck the "Desktop" Multiuser geodatabase(also known as SDE Personal Geodatabase), which comes free along with ArcGIS Desktop.But, there are certain things that you need to consider for the above type:1. You need SQL Server Express to use that2. Even though almost all the functionalities of SDE(versioning, replication, etc) is available with it...it has a limitation on the Number of Concurrent Users (1 editor and 3 readers)
To extent on this, I have written a detailed instruction of how to install a "Desktop Geodatabase" a.k.a. "Personal ArcSDE" a.k.a. "ArcSDE Personal Server". You can find it in this post in another thread.
Thanks for the link & the time you put into the step by step directions!
