By any chance this project targets .NET framework 4.0 (created via Visual Studio 2010 beta)?
I am getting an error "This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded" when targeting 4.0. I'm hoping that there is a workaround, esp after you've added support for VS2010 in Beta 2, so overlooking this seems weird.
You can workaround this issue by placing a esriRegasm.exe.config file in the same folder as esriRegasm.exe (e.g. under C:\program files\common files\arcgis\bin) with the following content <?xml version="1.0" encoding="utf-8"?><configuration><startup useLegacyV2RuntimeActivationPolicy="true"><supportedRuntime version="v2.0.50727" /><supportedRuntime version="v4.0.21006" /></startup></configuration>
