thanks for responding but how can i create a workgroup gdb here how i create mine: i connect to my database server (sql server) then i create my gdb if there is an other way to do it please show it to me and thanks again
hello i'm using arcgis desktop 10.2 and sql server 2008 express in the same machine just for test when more than 3 machine try to connect to my Geodabase (sql server ) they have this message :number of session exceededcan someone know why i have this problem knowing thati have arcgis advanced and sql server 2008 express the both accepte many connection at a time thanks
There's two types of Express-based geodatabases, the Desktop geodatabase, with 3 seats,and the Workgroup database with 10 seats. You seem to be using the former.- V
You receive this error because you are using Multiuser Desktop(1 editor and 3 readers) Geodatabase. If you want more users to connect to the Geodatabase, you have to get a Workgroup keycode (10 editors and readers) or an Enterprise GDB (Unlimited editors and readers).
What I meant was Workgroup GDB. Right now you are using Desktop GDB and once more than three connections are made to the database, you encounter error. If you want to make more connections to the database, you have to use either Workgroup GDB or Enterprise GDB. Please refer this webpage.
please can you explain more about what you said ,because i m using arcgis desktop 10.2 sql server express , and in an other machin i have arcgis server 10.1 workgroup edition so how can i use arcgis server to have more connection to my geodatabase
Enabling SQL Server Express to store workgroup geodatabases.
