But will Tkinter be packaged with the add-in when I distribute it? I distribute my add-ins to other people and I don't want them to have to install additional libraries/interfaces such as Tkinter (and in some cases they aren't allowed to).
Is there a way to use arcpy parameter like you would in a python toolbox?
# file_open.py import Tkinter import tkFileDialog import sys # Get command line arguments args = sys.argv args_len = len(args) # Create parent window and hide it from view root = Tkinter.Tk() root.withdraw() # Generate dialog options options = {} options['parent'] = root if args_len == 2: options['title'] = args[1] elif args_len == 3: options['title'] = args[1] options['initialdir'] = args[2] options['multiple'] = False options['filetypes'] = [('Special file','*.special'),('All files','*')] # Show dialog file_path = tkFileDialog.askopenfilename(**options) # Destroy parent window root.destroy() # Print result print file_path
import arcpy import os from subprocess import Popen, PIPE def open_file_dialog(dialog_title, default_dir=None): file_open = "file_open.py" file_path = os.path.join( os.path.dirname(os.path.abspath(__file__)), file_open) file_arg = [file_path, dialog_title] if default_dir is not None: file_arg.append(default_dir) proc = Popen(file_arg, shell=True, stdout=PIPE, bufsize=1) stdoutdata, stderrdata = proc.communicate() proc.terminate() return stdoutdata.strip() file_path = open_file_dialog("Open File") if arcpy.Exists(file_path): pass
