Run Add Surface Information with your DEM and polylines. It will return the surface length of the line. The sampling distance parameter defaults to the surface resolution which is what you're asking for so just leave that parameter alone.Best,Eric
Add Surface Information doesn't make your polylines into 3d polylines. Near 3d requires your inputs to be 3D. Near 3D is also not going to tell you the surface distance between points and polylines - only 3d distance. I think I misinterpreted your question at first.Perhaps some screenshots of your data overlaying each other so I can understand better.Best,Eric
The "add surface information" tool added attributes to the polylines (see attached), but I need Z information for the polylines at much higher frequency than the attibute provided (i.e., more than one Z value per polyline created).Earlier in thread:The polyline was manually created. I will need to extract elevation data from the DEM to every pixel along the poly-line. Without the Z data on the polyline, the distance I calculate will only be 2-dimensional and, therefore, an under-representation of actual distance from point to line as the data is in mountainous terrain.Matt
