I have some queries related to the smart edit widget
Hi Ahmad,
Thank you for posting your questions.
Is it possible to select value from drop list based on another drop list selection ?
If you are referring to contingent values (make values in one field dependent on values in another field), these are not currently available in Smart Editor.
also in the smart edit widget i can hide fields based on the user selection, but how i can show fields if it was hidden
Please would you be able to provide more details and maybe a screenshot to illustrate what you are trying to do?
Hi Alix,
Yes this what i meant, so how i can implement this ? should I create a custom widget or is there other way to do this ?
lets say i hide one field and i want to show it based on conditional selection (action), how i can do this ?
we can hide field based on an action but how i can show it if it was hidden by default ?
Contingent values are available in ArcGIS Pro. Yes, you can customize the Smart Editor widget for your needs in Web AppBuilder Developer Edition.
