Pokusil jsem se použít nástroj Calculate Accessibility Matrix, ale obdržel jsem chybu 000824: Nástroj není licencován.<\/P>
<\/P>
Mám Network Analyst, potřebuji ještě nějaký jiný balíček?<\/P><\/BODY><\/HTML>
You don't specify the software or version... so from support...
Error: 000824: The tool is not licensed
000824: The tool is not licensed.—Help | ArcGIS Desktop
In short, make sure that the license is toggled on if working within arcmap or checked out if scripting or you have access to the extension in the first place
Thanks! That worked!
Did you resolve this problem?
If not, could you copy and paste the full message text so I can take a look (not just the error message, but everything that appears in the geoprocessing window)?
