Hi All
Is it possible to create sequential unique ID field based on an advanced sorting of the attributes using Python? And without installing ET GeoWizards? (ArcGIS 10.2)
This doesn't work
38517 - Create sequential numbers in a field using Python in the Field Calculator
ET GeoWizards
SOLUTION for adding new sequential ID numbers based on sorted data
Cheers
If you like, post the code you used and we can help you debug it.
I just tested my logic and it worked in a file geodatabase. Here is updated code that is a little more flexible.
def main(): import arcpy import os temp_gdb = r"N:\TechTemp\BlakeT\Work\TEMP.gdb" fc = os.path.join(temp_gdb, "TEMP_Line") sortFieldName = "Note1" seqFieldName = "SeqID" # Step 1 existingFields = [field.name for field in arcpy.ListFields(fc)] if seqFieldName not in existingFields: arcpy.AddField_management(fc, seqFieldName, "SHORT") # Step 2 cursorFields = [sortFieldName, seqFieldName] sql_postfix = 'ORDER BY {}'.format(sortFieldName) with arcpy.da.UpdateCursor(fc, cursorFields, sql_clause=(None, sql_postfix)) as u_cursor: # Step 3 for seqid, row in enumerate(u_cursor, start=1): # Step 4 row[1] = seqid u_cursor.updateRow(row) if __name__ == '__main__': main()
And you don't have the advanced license either do you? Sort tool help
Yes I have advanced license
The link I provided has a discussion. You will at least be able to determine whether it meets your needs then.
It's one workaround, I would also get the same result by adding a new field (for the Unique ID's) , Advanced sorting the data, then copying attributes to excel, adding sequential numbers then copying back to Arc while editing. It would be nice to have the ability of field calculator with selections etc, using python.
Could you try something like this?
I haven't tested this, but here's an example:
def main(): import arcpy import os temp_gdb = r"C:\Temp\MyGDB.gdb" fc = os.path.join(temp_gdb, "MyFC") # Step 1 arcpy.AddField_management(fc, "SeqID", "SHORT") # Step 2 fields = ["OID@", "MySortField", "SeqID"] with arcpy.da.UpdateCursor(fc, fields, sql_clause=(None, 'ORDER BY MySortField')) as u_cursor: # Step 3 for seqid, row in enumerate(u_cursor, start=1): # Step 4 row[2] = seqid u_cursor.updateRow(row) if __name__ == '__main__': main()
Me thinks he is no longer interested having found a solution on one of several sites he posted the question on... python - Creating multiple fields with ranks using arcpy - Stack Overflow which references an Arcpy article Ranking field values | ArcPy Café with the cavaet that it doesn't work in these situations...
" Note: dBase (and shapefiles) does not support ORDER BY as used above by arcpy.da.UpdateCursor’s sql_clause argument. "
Looks like the solution posted there is very similar to mine. Thanks for the follow-up Dan.
Hi Dan, It's been the weekend here, hence why I haven't responded. I will check the code as soon as I can. Also this is the only post on this subject I have created.
Hi Blake,
Thanks for the code, I'll see how this works as soon as I can.
Blake, I tried the code but It didn't populate the new field.
I'll just stick to the Excel way as is will be quicker.
