QueryTask queryTask = new QueryTask("http://myGISserver/ArcGIS/rest/services/secure/Water_Utilites_Job_Log/MapServer/0"); queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted; queryTask.Failed += QueryTask_Failed; queryTask.Token = theToken;
http://beta.esri.com/community/[/URL]
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009"> <Grid x:Name="LayoutRoot" Background="White"> <esri:Map Name="MyMap" WrapAround="True" Extent="-15000000,2000000,-7000000,8000000"> <esri:ArcGISTiledMapServiceLayer ID="Street Map" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> </esri:Map> <esri:MapProgressBar x:Name="MyProgressBar" Map="{Binding ElementName=MyMap}" HorizontalAlignment="Center" VerticalAlignment="Center" Width="200" Height="36" Margin="25" /> <Grid Name="LoginGrid" HorizontalAlignment="Right" VerticalAlignment="Top" Margin="0,15,15,0"> <Rectangle Stroke="Gray" RadiusX="10" RadiusY="10" Fill="LightGray" Margin="-10" > <Rectangle.Effect> <DropShadowEffect/> </Rectangle.Effect> </Rectangle> <Grid> <Grid.ColumnDefinitions> <ColumnDefinition /> <ColumnDefinition /> </Grid.ColumnDefinitions> <Grid.RowDefinitions> <RowDefinition /> <RowDefinition /> <RowDefinition /> </Grid.RowDefinitions> <TextBlock Text="Username" Grid.Column="0" Grid.Row="0" Margin="2" VerticalAlignment="Center" /> <TextBox Name="UserTextBox" Text=" " HorizontalAlignment="Right" Margin="2" Grid.Column="1" Grid.Row="0" Width="140" /> <TextBlock Text="Password" Grid.Column="0" Grid.Row="1" Margin="2" VerticalAlignment="Center" /> <!-- Yes, the password is visible in this example. Use a PasswordBox to mask the password text. --> <!--<PasswordBox Name="PasswordTextBox" HorizontalAlignment="Right" Margin="2" Grid.Column="1" Grid.Row="1" Width="140" />--> <TextBox Name="PasswordTextBox" Text=" " HorizontalAlignment="Right" Margin="2" Grid.Column="1" Grid.Row="1" Width="140" /> <Button Name="LoginLoadLayerButton" Content="Login and Load Layer" Width="140" Margin="0,5,0,10" HorizontalAlignment="Center" Grid.Row="2" Grid.ColumnSpan="2" Click="LoginLoadLayerButton_Click" /> </Grid> </Grid> <StackPanel x:Name="EditorToolStrip" Margin="0,5,5,0" > <Border Background="#00919191" CornerRadius="5" HorizontalAlignment="Right" VerticalAlignment="Top" Padding="5" BorderBrush="Transparent"> <Border.Effect> <DropShadowEffect Color="Black" Direction="-45" BlurRadius="20" Opacity=".75" /> </Border.Effect> <StackPanel Orientation="Vertical" HorizontalAlignment="Right" Margin="0,5,5,0" VerticalAlignment="Top" > <esri:EditorWidget x:Name="MyEditorWidget" Map="{Binding ElementName=MyMap}" Width="300" AutoSelect="False" AlwaysDisplayDefaultTemplates="True" GeometryServiceUrl="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" ShowAttributesOnAdd="True" Loaded="EditorWidget_Loaded"/> </StackPanel> </Border> </StackPanel> </Grid> </UserControl>
using System.Windows.Controls; using ESRI.ArcGIS.Client; using System.Windows; using System; using System.Windows.Threading; namespace Secure3 { public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); } private void LoginLoadLayerButton_Click(object sender, System.Windows.RoutedEventArgs e) { ESRI.ArcGIS.Client.TokenManager tokenManager = new ESRI.ArcGIS.Client.TokenManager() { UserName = UserTextBox.Text, Password = PasswordTextBox.Text, TokenSource = "https://xyz/arcgis/tokens", AutoRefreshing = true, Expiration = 5 }; tokenManager.RequestTokenCompleted += (s, a) => { if (a.Error == null) { LoginGrid.Visibility = System.Windows.Visibility.Collapsed; MyMap.Layers.Add(new FeatureLayer() { Url = "http://xyz/ArcGIS/rest/services/secure/Water_Utilites_Job_Log/FeatureServer/0", Token = a.Token, ID = "Job_Points" }); } else { MessageBox.Show("Error: " + a.Error); } }; tokenManager.RequestTokenAsync(); } private void EditorWidget_Loaded(object sender, RoutedEventArgs e) { string[] myLayerIDs = { "Job_Points" }; MyEditorWidget.LayerIDs = myLayerIDs; } } }
Did Chris' suggestion work for you?
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
