Look at the KB link inside this forum post. Your problem might be related to how the security is set on serverhttp://forums.arcgis.com/threads/82989-Deployed-Apps-not-showing-up-in-Builder
Many thanks guys for the help,All what I did is giving the user �??never notify�?� property in the user account control (UAC). And it did work. I could edit the applications[ATTACH=CONFIG]24048[/ATTACH]What do you think?BestJamal
"Never notify" means that you also will no longer receive messages when any malicious software attempts to make changes to your server. Making a more "surgical" change by following the instructions in the link posted by PietaS175 and only allow the minimum necessary to solve your issue is a more appropriate action if you like to follow "best practices".
