We are facing issues with our saved mxd. The mxd with a particular feature class in enterprise geodatabase (Oracle 11g) is crashing with no error message. We tried with mxd Doctor but no luck.
Can anyone help on this?
TIA
S
Sovan,
Please provide the following information which might be helpful to troubleshoot the issue: -
I hope this helps!
~Shan
If the featureclass crashes a blank new project, then try running a repair geometry on it
Repair Geometry—Data Management toolbox | ArcGIS Desktop
Repair geometry accepts a featureclass on disk unlike check geometry.
If the featureclass doesn't crash a new project, then try adding the remaining data... it may not have been that particular fc but other data associated with it
Please find below
I want to add following observations
In ArcGIS 10.3.1 a Python script to convert mxd to pdf did not run but it worked well in 10.2.2.
The issue is with only one particular fc. The fc is added in a blank mxd and saved. lLater when tried to open the mxd it crashed.
did you run a check and repair geometry on the featureclass before saving the blank mxd.
Now that you know that the fc causes issues with the saving and reopening, you have to see if repairing the fc will allow a project to be saved and reopened with it in it
I do agree with Dan at this point. However, I would suggest you to go ahead and run the Check Geometry—Help | ArcGIS for Desktop before you run the Repair Geometry—Help | ArcGIS for Desktop . I have had a bad experience where I executed repair geometry without check geometry and there was some data loss.
Check Geometry tool is not working as the problem FC is in SDE. I tried to run copy feature class tool but it failed.
