I have the exact same problem. Thank you very much to post a workaround to the issue.
ESRI is most disappointing for not fixing this bug. This bug has been around for as long model builder exists. It should be a really easy fix yet they don't bother.. #monopoly #coorporategreed #ESRIsucks
I wish I had never gotten addicted ArcMap and that qGIS had been around earlier.
Hi
Did anyone solve this issue? I am using a model to run hotspot analysis for each of 52 districts. I would like to specify the processing extent (raster analysis mask) for the density surface output for each district rather than the default convex hull.
Any ideas?
harry
