mapServiceLayer.getLayerDetails(...)
Hello,I am doing a small ESRI JS API project and don't use it too often so the library is new to me..Anyways.. I cant find anyway to get field information.I am trying to write a function that will determine what the the OBJECTID field name is based on its data type (esriFieldTypeOID)The object is in the documentation (Field) but I can't find a way to get a field?In the Flex API you can call a a function like so... mapServiceLayer.getLayerDetails(...) Please help me get a fields array.Drew
Thanks Alex. I think I can work with this!Drew
fieldAliases Object Set of name-value pairs for the attribute's field and alias names.
type String The data type of the field.
var mapLayer= new esri.layers.FeatureLayer(layer.url,{ mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"] }); dojo.connect(mapLayer, 'onLoad', function() { alert(mapLayer.fields); (undefined) alert(mapLayer.version); (undefined) });
when you call a method, you know that it has done all of its work and returned something useful. Right? Well�?� not always. Sometimes that method will invoke web requests that need some time to process, or it may call another method that has to do some processing or is waiting for user input�?� These kinds of operations can be implemented asynchronously, and the only way to manage that logic programmatically is with a callback parameter.
When the layer is loaded, the value becomes "true", and layer properties can be accessed. The onLoad event is also fired.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
