Note that while people have success with these tools, they are unsupported by Esri.
Mike,
Can I retain my original AGOL accounts while making the transition to AD?
Or once I establish ADFS as the identity provider, can my users no longer login with AGOL accounts to our Organization
Yes, you can maintain both your AD accounts and AGOL accounts. They are considered separate accounts. Now, you'll probably want to consolidate, as each account consumes a "named user" in the subscription.
Mike
We are in the process of rolling this out to our organization, and we have been using the firstname.lastname_<org_ID> already with the AGOL Enterprise Login. If we configure our NameID to be firstname.lastname_<org_ID>, will users be able to login to their already established accounts, there by making the roll out 100x easier?
Also related, would creating a pre-established account for users with the same NameID that would be coming from AD allow users to get to the already pre-established account?
Unfortunately, you can't can't configure your enterprise logins to use the same username that already exists in AGOL. If you do this, the enterprise login will fail because a username already exists.
However, this is a good idea and I'll write it up as an enhancement. I'm not sure what it would take to do this, so no guarantees...
Hi Mike,
Thanks for the reply and for offering to submit this as an enhancement. I would think this is a pretty common occurrence since the default AGOL organizational account naming convention uses the username of the new user's email address, and that username is typically an organization's enterprise login username.
One clarification: if an enterprise AGOL account name already exists, will the login fail, or will AGOL create a unique username using the patten <NameID>_<OrgID>? For example, if tim.haverland_noaa exists AGOL will create an account name like tim.haverland9_noaa?
This has important implications for how we plan for a migration to enterprise logins.
Tim
Just to be clear, you have created logins for AGOL that don't use enterprise logins. Now, you want to activate enterprise logins and use the same username that exists already in AGOL. Attempting to login with an AD login that matches an existing AGOL login will fail. The system won't try to create a new one.
I spoke with our developers here and they said in order to implement active directory you could
"change the NameId saml attribute that is returned from the IDP to be something other than what they were sending so it would not conflict with the existing usernames."
This means modifying what Active Directory does, which could impact other things in your organization. The only other thing I can think of would be to introduce another manual process of creating new usernames for all employees, transferring existing content to that username, then to delete all the old usernames, then activate enterprise logins and sign in again and transfer all content.
not the best news...
Has there been any changes to moving users over to AD accounts within AGOL?TIA
Jill
