I'm using ArcGIS JS 4.6 to create a webmap for mobile devices and using the Track widget to get the device's location. On both iPad and iPhone the Track widget is failing to fire the "track" event. Using iOS >= 11
This code snippet shows the event listener. This code is never reached on either iPhone or iPad. On android devices and desktop browsers this code is reached.
<SPAN class="keyword token">var</SPAN> trackOn <SPAN class="operator token">=</SPAN> track<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'track'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>Any ideas anyone?
