It doesn't exist.
Where did you use it before? Part of ArcMap? A toolbox? an Addin?
EDIT
This is the closest since you can extract parts in a desired format
Convert Time Field—Data Management toolbox | Documentation
Thank you for your reply.In toolbox, but i cant find this.
Thank you for your reply.In toolbox, but i cant find Extract Date Parts To Field tools
The tool doesn't exist in ArcGIS Pro. My question is where did you come across this tool? Did you use it before? And if so, did you use it in ArcMap?
I never use this. I will use this in crime analysis. I think i cant find this tools in arcgis pro. Can I find this in ArcMap?
It may be a crime analysis toolset
Crime Analysis Solution Add-In Ribbon for ArcGIS Pro
