For instance I click the center polygon graphic; the pagination illustrates the correct 3 graphics to paginate through. As seen in the screenshot below:
However, when I click the outer polygon graphic here; the pagination doesn't include the same 3; which should be to navigate inward - instead it doesn't include any... Screenshot below... then if I click the middle one, I can only paginate to 3, not one - again only including outward. So the problem is pagination can paginate displays correctly from inner to outward, but doesn't include any inner from outward.
And the outmost outer; including nothing below as highlighted:
perhaps related to this? Any updates? https://community.esri.com/thread/191980-multiple-features-in-v4-popup
