I have tried PNG as well. Neither image works for custom background on home page, but according to Portal Help it should be fine. The error message is very generic.
What is the size (and dimension) of the image?
Configure home page - Portal for ArcGIS
If you want a single, nonrepeating background image, for best results, the image should be 1,920 pixels wide (or smaller if your users are on smaller screens). The website does not resize the image. You can upload a file up to 1 MB in size.
Thanks for the response.
I have tried JPEGs and PNGs, and all are well under posted size limit a width and just about 40 kB
Have you tried using IE? There's a bug in Chrome and Firefox when trying to upload various things like images/metadata: Announcement: Errors Encountered in ArcGIS for Server and Portal for ArcGIS Web Apps after Certain Browser Updates | Sup…
Carmel
Thanks Carmel!
That must have been the issue, because same images uploaded fine in IE7 vs Chrome.
Much appreciated.
Excellent! I've installed the fix on my Portal 10.4.1 instance and it resolved the issue just fine
Carmel,
I seem to be having the same issue with ArcGIS Enterprise 10.5.1. I am able to upload a custom banner image, but get an error ("There was a problem uploading your custom background") when trying to upload a custom background image. The image is a .png that is 420 bytes in size. I tried to upload the same background image using Chrome, Firefox, IE, and Microsoft Edge, all with the same error. Do you know if there is a patch coming for 10.5.1 to correct this issue?
Tim
Hi Timothy,
I'm not aware of a 10.5.1 patch - it might be worth submitting the issue to your Technical Support team.
Are you able to share the image on here and I'll try it in my instance?
I had the same problem in both Chrome and IE. For me, the issue was that the path of the file was too long. Saving the exact same PNG file to my desktop and uploading it worked.
