If the proxy is adding a token and no security error is returned to the client, then the IdentityManager should not be showing the sign in dialog.Since creating an instance of the Portal also enables the IdentityManager, try adding this after line 45 of PortalBasemapAppender:IdentityManager.instance.enabled = false;
